Root Does the backside rom fixx the cell standby battery drain bug?
Hi
I recently installed the backside rom onto my device and was wondering if it fixed the battery drain bug the V has. Ever since i installed it, my battery has gotten worse. The time without signal is 0% but the cell standby is still high for some reason.
Thanks
You are referring to the Time Without Service bug, and yes, that is fixed in IHO. Sounds like you have poor cell coverage where you are, join the club. ;)
What I do when in a dead zone (like my home), is use wifi only, and then use 3g everywhere else. I get over a day on battery this way (up to 32 hours with light usage).
Agreed, this method works wonders for battery life. I also get about 30ish hours of light to mild use. IHO is a godsend.
