This is not a battery life thread, in short all I wish to know is whether the Droid X battery (which stupidly only reads in 10% intervals) is reported higher or lower than its actual value?
For example, when it is at 70% reported, is it at 79% (or lower)? Or is it at 61% or higher? Obviously logic says it rounds down so it is always showing battery levels lower than it actually is (which is good because your battery is always higher than what it tells you), but it is also plausible that it ticks down (to 70%) when it actually hits 70%, then stays there until it gets down to 60%.
Not really a support question but its something I've been wondering, I assume it is the former as that makes the most sense from both a mathematical standpoint and a logical standpoint (show less battery than you really have left and you will not run out of battery when the phone goes into its battery reserve state).
