I have not seen that, Today I put my phone on the charger at 25% battery left and it listed time since last charge 2 days 8hours 3mins.Any tips for making the Optimus M battery last longer? My wife can't make it half a day without the battery dying. She's not even using it THAT much. Any help?
I leave wifi enabled but turn off gps, and sync when not in use, screen is always at full brightness.It's not the battery that sucks, it's the bloatware. To make up for it (in a non-rooted environment) you can take the steps that thunderkiss mentioned. Some people also look to apps like Juice Defender to help manage things in the background and conserve battery.
My phone is rooted and can probably last up to two days with light usage. So far my best is a day and a half with moderate use. I also leave sync, GPS, and WiFi enabled along with full brightness.
The accessing of the sd card may take a small fraction more power, but not enough to lose even 30 mins of battery. And having a larger sd card is not hurting it. I could not tell you what is the problem but I can tell you those things are not.if it makes a difference, I keep a lot of apps on my sd. does it take extra/more battery life to keep the transfer from sd to phone, back and forth, more-so than simply having the resource on the phone's internal memory.
also, I have a schlitz-ton of music on my 32 gig sd. I feel like that is a dumb question, but could that have anything to do with it? 32 gigs? maybe that's it... which would rly suck.
orly?
yrly.
ok, I'm done talking to myself there.
thanks to any and all who can shine some light on this.![]()
ok initial thoughts they are using feature phones, and or old android versions, android 2.2 and newer has much better support for sd cards, plus those posts are about a year old, sd card tech has improved substantially in that time frame.Thanks new optimus -
the timing on this is good - I'm reading your post, though I've just found this
Battery performance and microSD card, interesting observation [Archive] - xda-developers
thoughts?
this is about one year, this thread.
is there something I don't know?
I'm going to try using my 2 gig micro sd card and see what the difference is. worst-case I have to figure a clever way of carrying my micro sd 32 gig without feeling that I might lose it.
ah, could be the class of the card, class 4 is fairly slow, it may account for part of the problem.you're right there.
its an old post. and all of what you say should prove true.
for me, just me, it seems from my experimenting today
that it is my card.
switched out the 32 for the 2 (stock from metro) and the change is night/day.
now the question is
if it is my card,
what can I do about it?
or, if its the firmware... I'm running the stock 2.2.1 froyo w/ gingerbreak -
the 32 gig is a sandisk sdhc micro class 4.
thoughts, or should I keep looking for other reasons besides the correlation of my card as perhaps a fluke on my assessment?
