Dolphin Browser Help Needed ?
Hi,
Does anyone know if you can change the options you get when you press the menu button ?
Also can you change the order your bookmarks are in ?
Thanks....
you cant change the options for the menu button.
I'm not sure about moving bookmarks, try pressing menu when looking at the bookmarks, or try long pressing on a bookmark item.
You CAN move bookmarks in Steel btw.
