B bradm23 Member Jun 7, 2010 #1 Seems like mine forces closes more than I would like. I downloaded the HD one for my inc. What's the difference between the HD and reg one? Also any other better or comparabers browers out there?
D Deleted User Guest Jun 7, 2010 #2 I'm running Dolphin Browser HD and never had any FCs. Maybe there's some kind of s/w issue?
Steven58 Former Heavyweight Champion of Android Forums Moderator Jun 7, 2010 #3 General_Crespin said: I'm running Dolphin Browser HD and never had any FCs. Maybe there's some kind of s/w issue? Click to expand... me neither. are you using a task killer by any chance?
M mickskillz Newbie Jun 7, 2010 #5 delete task killer, it's a waste if you don't use it, and can cause more problems then it's worth
