Help Double Calendar Reminders
sashao
I synced my calendar on my phone with my Outlook calendar. Each event only shows up once on my phone calendar, but I keep getting 2 reminders for each event. Does anyone know why this happens?
Can you check something,
Open an event, menu.edit and go down to reminders, are two present?
It sounds like you set up outlook corrrectly, but now it has synced to google and is displaying both
Also check menu.settings.accounts and sync.google
Uncheck calander
Assuming outlook is also listed that should fix it....
I do not use outlook so I am completely guessing here
What are you using to sync Outlook. I would far prefer to be able to do that rather than screw around with Google Calendars and cloud tech.
I just went to the e-mail on my phone and added the account that I use with Outlook, which is my work e-mail. You should be able to change the settings to see if you want to sync all, or just the calendar, or just your contacts, etc.
Are you syncing OTA or with a USB connection?
