I installed handsent and I have double notifications now I did a search and did the reading but it no real answer has anyone found a real solution for this problem thanks for any help
Menu > Setting > (Scroll to the Bottom) > Un-Check Notifications
This should stop the Pre Installed SMS application from Notifying you of new Messages. Allowing Handcent SMS to be the only one to notify you of new messages.
