empty_cups
I am really annoyed with this double lock business. How does one go about downgrading to the previous OS so I can disable all locks, and then upgrade again so I can just have my pattern lock?
Again, how does one revert back to the previous Firmware so I can set the Droid-x to no lock, then upgrade to Froyo and have just the pattern lock? Or is this not possible?
Funny i had the slide lock off before update. Now i dont have the option to turn it back on. Just Pin, Pattern, Password.
So, I wrote to Verizon support about the problem, and they gave me a number to call Motorola. The Motorola tech told me to do a factory reset. So, I tried it, and it did not fix the problem, and now I am re-installing all my apps. Sigh.
Can't get rid of the slide lock at all now that I did the reset. Before, I could turn off all security and there was no slide lock, and when I turned on Pattern, I had both.
Grrr.
