Help Double Tapping on Droid X
gocard
I just demo'd the Droid X in store today. One thing that annoyed me was having to double tap on things like menu items, when I wasn't used to having to double tap those before. Here is what I'm talking about (take a look as he double taps the "More" icon at 3:34 in the video): YouTube - Motorola Droid X Walkthrough
Is there a way to turn that off, so I only need to single click?
The only time you should ever need to double tap is zoom in the browser or to force the browser to fit the text to page if you pinch zoomed.
I have the reverse problem ... the demo phone had it turned on, but on the one I bought it's all single taps. Where the heck is this setting?
The reason people are having trouble with the 'double tapping' feature is beacuse you are looking for a setting called double tap. Unfortunatly its not that simple.
The double tapping is a side affect of another feature on the phone for the visualy impaired.
For those who want it turned off, go to Menu-- Settings--- Accesability--
and uncheck the box, the bottom one... its called spoken menus or something like that. or just turn accessibily completly off by unchecking the top box.
For those who want it turned on, go to the same menu and check those boxes.
Once those boxes are on, you might start hearing an annoying voice reading everything you select to you.
To turn that off, go to sound and display settings and uncheck the box that says 'audible selection'
wala--- now you have double click action with no annoying speaches.
