Doubt in X10 mini pro
banmidou
Hi all,
I bought X10 mini pro two days back. I wanna know whether we can remove the auto lock (unlock the mobile using the slide option from left to right) from this mobile and use the draw pattern alone to lock and unlock the mobile. Right now whenever I wanna unlock the mobile, the unlock by sliding from left to right in the screen comes up followed by the drawing pattern that we set. So can anyone tell me whether we can remove this slide unlock option?
It's already been moved, don't worry about reposting it. Not a problem, it's all a bit confusing when you are new to the forum.
I tried using this but it is disabling the drawing pattern with the slide to unlock. Is there any way to disable the slide to unlock alone and use the draw pattern to unlock???
