Root Downgrade LG Optimus M from 2.2.2 to 2.2.1
Is there any successful way to downgrade from 2.2.2 to 2.2.1?? I updated my phone to 2.2.2 and lost root. Now im trying to get back to 2.2.1. any help please? :(
Thank You
check your antivirus, it may be hindering you.
Also you need admin rights, turn off UAC.
Thanks for the tip, but i had already figured everything out already, lol i am now back to 2.2.1 :D
it was something on my laptop that was keeping it from working, that was probly it but i just switched over to my desktop and everything worked perfectly :)
Thanks though :p
I wish I can downgrade back to 2.2.1. Everytime I try this method, The part with the bin says (This file path is empty) Even though I have it placed in the slot. Any Ideas?
winrar will handle 7z files.. but if it doesnt work with you.. theres nothing wrong with installing something for more support
I am a total noob, but good at following directions. I tried the LGNPST method, but the "bin" area is greyed out and when I try to load the dll with file>load dll, the resulting popup window is empty.
Any ideas on what I need to do?
