ok...now when I try to push a new build.prop I am getting this...wtf?
"failed to copy 'build.prop' to /system/build.prop': permission denied"
Through ADB right?
If so do
adb shell
su
then on your phone hit allowe.
Shouldnt it be?
"adb shell"
"su"
"mount -o remount,rw -t yaffs2 /dev/mtd/mtdblock4 /system"
"adb push build.prop /system/build.prop"
"exit"
Your computer can't find your adb file so you need to add it to your computer's path.
My adb.exe is in D:\android-sdk-windows\tools so I have to add
D:\android-sdk-windows\tools;
to the path, making sure it's preceded by a semicolon. Obviously your location may be different. Use these instructions to add it to yours before proceeding. (Should work for all versions of windows.) How to set the path in Windows 2000 / Windows XP.
... and adb.exe is in C:\users\draconius\desktop\tools?
You're positive that's the exact spelling of the folder?
What's up with the spaces in System32 and WindowsPowerShell?
Shouldnt it be?
"adb shell"
"su"
"exit"
try putting the phone on mass storage or sync mode, i heard others say those work
There are no spaces in the path...must have happened when I copy/pasted into the forum...weird.
Positive. Here is a screen cap of my tools folder:
cd C:\users\draconius\desktop\tools
adb
path=C:\users\draconius\desktop\tools
