Root Droid Bionic Fastboot [FXZ] Files
Here is a link to all the relevant Bionic stock files that I could find. It seems many links are dead so I hosted these myself.
Hope this helps!
Thank you very much for hosting these files! I used the 902 FXZ file to repair a bricked Bionic and then used an OTA upgrade to flash it to 905... :)
Very helpful!
Very helpful!
You are welcome. The Bionic scene is very quiet right now. Not sure if that will change or if it will go the way of the Droid X....
which of these would a person be on if they never had rooted their phone and installed leaks and roms and what-not? I'm assuming 904 and 905 are not official updates since they are labeled "leaked" in this thread, so I'm assuming everybody is on 902 who hasn't rooted? Will I need to be on 902 in order to receive any future OTA updates like when/if ICS ever comes out?
It says to flash it in stock recovery, but that won't work if I'm on .232 will it? Won't I have to use RSD Lite?
it's telling me to check my input file. either XML format is wrong or image files associated with it are missing.
I'm resurrecting this thread b/c it has all of the old FXZ files, and I'm adding my link for the latest (ICS) FXZ.
NOTE: If you use the 6.7.246 FXZ you're permanently on ICS - there is no going back to GB from ICS. The security in the CDT.bin file has changed, so once you install it it's stuck on there, you can only move forward.
VRZ_XT875_6.7.246.XT875.Verizon.en.US_CFC_01.xml.zip
HTH
So i have a factory Bionic, it was on GBbuild. 905.
I tried flashing to ICS and got an error on i believe 19/22.
I think i got in over my head, anyone wanna give a noob step by step how to use these and what one to use?
I have a backup phone so its not urgent, but still id like to salvage my expensive paper weight lol.
Thanks in advance.
I tried flashing to ICS, i didnt get the downloads from these links. Im not around a computer to try them, but i tried a version of ics, i forget the exact build, and then tried going tried going back to the. 905 which stoped at somthing like step 6 " cdt" Im not sure if thats exactly what i got
Ok use the 6.7.246 from my thread I know it is good. Once you go to ics you cannot go back to gb thats why you got the cdt failure.
Is your battery charged? What was it at when you started this process? Do you have another battery or some other way to charge your battery besides your phone.
you can do the manual method instead of using rsdlite because rsdlite can be fussy.
download this file and unzip. moto-fastboot
unzip your6.7.246 fxz file (the one you downloaded from my thread) to the same location as moto-fastboot
I believe your phone is in fastboot already if not press and hold the volume down and power button at the same time on the phone. The fastboot menu will appear. plug your phone into your computer.
navigate in windows to the location you have everything unzipped to. click on the file symbol in the top left corner and when the bar becomes highlighted type cmd and enter if you have win 7. A comand prompt will come up. If not go to start and type cmd and hit enter. when the prompt comes up type cd c:\location of file with moto-fastboot and fxz file unziped
type and hit enter after each step
moto-fastboot flash mbm allow-mbmloader-flashing-mbm.bin
moto-fastboot reboot-bootloader
moto-fastboot flash mbmloader mbmloader.bin
moto-fastboot flash mbm mbm.bin
moto-fastboot flash cdt.bin cdt.bin
moto-fastboot erase cache
moto-fastboot erase userdata
moto-fastboot flash lbl lbl
moto-fastboot flash ebr ebr
moto-fastboot flash mbr mbr
moto-fastboot flash devtree device_tree.bin
moto-fastboot flash system system.img
moto-fastboot flash boot boot.img
moto-fastboot flash recovery recovery.img
moto-fastboot flash cdrom cdrom
moto-fastboot flash preinstall preinstall.img
moto-fastboot flash webtop grfs.img
moto-fastboot flash radio radio.img
you should be on 6.7.246
all your data except on your sd-ext will be erased.
I need to get some money together to pay for MF hosting again, but I'll have both the 98.72.22 OTA and FXZ hosted shortly.
You may wish to put in instructions how someone can use the cdt.bin file from the 246 FXZ to replace the one in 22 thus allowing someone who has not upgraded OTA to be able to downgrade to ICS again thus allowing them to regain root in case they lose it in JB.
