Droid Functionality
How can I move apps from the application menu to my main screen?
Welcome to the AF forums and enjoy you visits !! :cool:
Couple of ways ....
1.) on your main screen touch a blank area of the screen and hold for a bit (this is called a long-press) a menu will pop-up and you can then select applications ... select the app you want and a shortcut will be placed on your desktop.
2.) from the apps tray ... long-press the app you want to place on the desktop ... the desktop will reappear with your finger still down move it to a blank spot where you want the short-cut and lift .... viola short-cut to app is now on your desk top ....
to move short-cuts just long-press and drag to new position ... if you drag it to the apps-tray tab then you can drop it on there and it will remove the short-cut from your desktop ...
Other questions ... Please ask then in your phones forum
Enjoy !!
