I just got a Droid and had a couple questions:
1) What exactly does rooting your phone do?
2) Will i still be able to connect to a Wifi connection?
3) Will I still be able to tether? Will Verizon know I'm tethering?
4) Which is the best Rom to use for a newbie?
5) Can you update your themes separate from the Rom?
6) What is a kernel?
Also if you could update me to instructions to have to change Rom's and Themes I would appreciate it.
Thanks!!!!!
Thanks!!!!!
