After upgrading to .595 is anyone else having trouble with their undervolting not being applies at boot? I have a custom setting thats preset to apply, but I have to manually enable it anytime I reboot my phone.
That might actually explain my really inconsistent battery life.I've had to do the same thing starting with the first GB leak and continuing with this one. I really don't mind doing it manually, it only takes a few seconds.
Turns out there is a problem with the odexed version of .595. I could never get Busybox to install correctly and when I used D2 recovery to create a backup, it got stuck in a boot loop. I had to SBF back to .340 and make my way back to .595 again. THis time I used the deodexed version and all is working.
yup, this seems to be my problem as well with busybox
can't get it to install, busybox installer faults out, so I'm going to probably end up following your steps
ugh, SBF time again, all for an incorrect file
I'm running 595 deodexed and am not having the problem. I did get the "busybox not installed", but I was able to install it.
Yes.And the overclock is sticking after the reboot?
Couldn't you just install the deodexed update over the odexed version already on the phone? I would try that before SBF'ing.
If you don't want to apply the deodexed version of .595 over your current setup, you can apply this deodex zip I made instead:
GB_2.3.3_4.5.595_Deodexed.zip
possible - would it be best to wipe data/cache before doing this? maybe no need?
the other problem is that I can't seem to get D2 bootstrapper to download onto my phone - don't understand why
so, if I disable USB debugging, will DX bootstrapper actually work? or would it be better to use the ROM Manager to boot into Clockwork Recovery?
Wonder why D2 bootstrap won't install.
oh good grief, unchecked USB debugging and still bootlooped
Did you get my PM?
