cmoney12051
i got a droid from my friend a few days ago, and the only real problem with it is that the power button does not work. I have been trying to root it but cant even get to the bootloader screen. What i do is i take out the battery then hold the up button on the dpad, then replace the battery. and all i get is a black screen, no text or anything. i can get to the android bootloader by holding x then volume up and camera button but not this bootloader. i have tried letting the battery run low, all that results in is the droid shutting off and not turning back on untill the battery reaches 30%. so basically all i want to know is is there a way to root a droid with a broken power button, and how do you go about doing that?
P.S. it is running stock 2.1 update1
If the button is totally unresponsive, call motorola and get a warranty replacement.
