Help "Droid" Robotic Voice sound when booting up.
mattwill
Member
I want to use the "DROID" robotic voice that came with 2.2 update as a notification. For example, when a text comes in possibly. I like it. But it isnt listed as a sound file. Does someone have it as a file they can send me. Or a link to DL?
On the same note, I loved my old "Sonar" sound from blackberry. I want that one too, but also cant seem to find it.
It is called VZW_Droid.mp3 I believe if you are rooted and want to look for it. Probably located under /system/media.
Zedge ringtones and wallpapers app, search droid under ringtones, i use the one made by mariel 1970 for when i get a text message.
