jellomania
Okay so i've had my droid for a year now. it's time for an upgrade. Okay this may be long..
I ordered a droid x from wirefly (never again, but another story entirely) for my husband who is currently using a storm (yes, the OG storm). when it came in we set it up, and a couple of issues arose.
First, it would NOT sync to his google calendar until I factory reset the phone and tried again. When I first sync-ed his google account with the phone, he did not have a calendar set up; i did it after the fact, but before the factory reset. Will it never sync with calendar after the initial sync?
Second, after less than 24 hours the camera app stopped working. if you opened it, or pressed the shutter button the screen would flash black, and then go back to the home screen. I installed a couple of other apps that use the camera and they all worked fine, so I can be relatively certain it wasn't a hardware problem. Is this a common problem? or was this just a fluke?
That phone has been returned to wirefly and we're just waiting for them to change our upgrade back before we order two from verizon.
So questions for me.
Coming from a droid (i'm not considering the droid 2 because i never ever ever use the actual keyboard so it's useless to me-i much prefer swype), will the actual buttons(home, back, menu, search) on the phone be bothersome? or is it one of those things you just get used to?
My droid's battery is absolute crap. I can't go more than half a day (about 4-5 hours, usually less) without charging my phone. is the X's battery any better?
is size an issue? or again, is just a getting used to it thing?
thanks!!!
thanks!!!
