Try pressing the power button so that the screen is blank, take out the battery, put it back , then turning it on regularly. Worked for me![]()
My droid will only display:
Bootloader 2C.6C
Battery OK
OK to program
Connect USB
Data Cable
Tried power off, removed the battery
if I power on or plug in I get the above
Is it dead?
Thanks,
Barry
nope, not rooted, not dropped (never), not wet
mebbe a power surge thru the charger??
I noticed a couple days ago it was acting wierd. Camera function kept opening on its own, but a reboot fixed that
Verizon will be sending a replacement under the 1 year warranty, but warehouse is empty today
Does anyone know how long the wait is...and likelihood of a rebuild or a new one?
I had the same issue with mine and was able to get it to boot from the hard reset screen. The hard reset mode will give you several different options. I choose the first least involved which was a simple reboot and everything returned back to normal. It also gives the option to wipe the device which may work if nothing else does.My droid will only display:
Bootloader 2C.6C
Battery OK
OK to program
Connect USB
Data Cable
Is it dead?
Thanks,
Barry
