Help Droid x and google calendar?
billy345
I put in a appt. on google calendar from my computer and when it appears on my droid the time is off 1 hour everything else comes in ok(the day and details of the appt.) but the time is off 1 hour. If I enter an appt. on the droid the time is off 1 hour on the computer this just started doing this a couple of days ago. I checked all settings in google calendar and on the droid it is set to network time.
Thanks billy
Thanks billy
It would seen as if your computer if set to the wrong timezone. Check that.
Billy, I live in Arizona also and the same thing happens to me. Google calendar on my computer is set to Mountain Time - Arizona, and my computer time is set correctly.
Perhaps someone has an answer.
Don't you guys do Daylight Savings Time different in Arizona? I'm betting that's what the problem is.
