Accessories Droid X Compatible Headphones with mic and control?
I have these: FMJ Black and I like them a lot. gives me really good sound and the cord is kevlar wrapped so it's stayed together nicely. I use them everyday at work and the only problem is the plastic at the connector has broken a bit, but they are over a year old. I'd recommend them to anyone. I can also confirm they work well with my X
Are you able to switch tracks on any music player?
Also, are you able to answer the phone, say when you're out on a run?
I really want these 50/50 skullcandy headphones, but I dont think they will work with Android. Thats a deal breaker for me, since I sold my ipod to make my DX my only music player. I need the mic and in line controls to work.
50/50 Black/Red
50/50 Black/Red
I'm in the same boat as you. They look like pretty decent headphones but no where can I find info on Droid X compatibility.
I guess you could try droid shuffle. I've never used it, but it's supposed to emulate the iPod "shuffle control" for headsets with the controls on the cord.
But if it doesn't work then you have just spent $50 on a headset that won't let you control the music / phone.
If you don't mind, I think I'll put this in the accessories section.
Hi! does the mic work for your Droid X?
Thanks!
