Root Droid X Gingerbread - modification (TranQ_Gspot Preview)
Steven58
Former Heavyweight Champion of Android Forums
Moderator
Credit to P3Droid:
"This is a mod that i've started for TranQuility _Gspot
You must install this via clockwork recovery.
This will add 10% battery meter and CRT off animation.
There will be more than just this in the toolbox in the future. Just a preview of what is to come."
Download Framework Mod
so this will replace the battery icon in the status bar is there one that matches the stock one with percentages inside
I'm a bit curious: if the battery mod is for 10% increments, why are there viable images for 1% increments there?
some version of android come with images for 1% battery increments...so he is just replacing them all instead of the 10% increments.
i was a bit confused by this post so let me explain.
when you flash it, you will have the screen off animation and the first battery meter shown. this does NOT give you the toolbox like i thought it did. :(
either way, flashed it over my rooted GB, deodexed, and already screen off animation-ed build. everything works fine. it would be sweet if someone could get 1% battery increments.
I was non-plussed by this as well. Meh. Just thought I'd let you all know.
