Help Droid X keeps freezing and requires battery pull-- HELP!
tbrd89
The past week, my Droid X has been freezing several times per day to the point where I have to pull the battery. I let it sit for almost an hour and it remains frozen. This is super annoying. It usually happens after my phone has been in my pocket. Does this mean it's overheating? If so, why is it doing this now? I've had my phone for several months and haven't had any problems until the past week.
Any ideas?
means some new app you downloaded is running in the background and locking up your CPU, or at least that's my guess...
Uninstall apps from the last in to be the first out and see if that helps. If it helps, you're set. If not, you may need to do a factory data reset. Let us know. PM me if you're stuck. Good luck! :)
