No, i haven't.You have any apps installed that interfere with the lock screen?
Thanks, i will try that app.In 2.2 it seems if you want the slide lock you also have to use either the PIN, Pattern or Password lock. You can no longer just use the slider by itself since the upgrade. You could just leave it off and get Widget Locker from the app store. It will give you a slider without having to use the other locks.
Hi,
Since this qualifies as a support issue, I'll move it to support for ya!![]()
