I think the Droid X2 is a great device. The screen was the main selling point for me and it turns out to have a great display. I am very satisfied with this phone.
Has anyone experimented with headphones and had the ability to adjust the volume with the rocker while the phone is locked and display off?
Think I might return my DX2 if I don't hear anything about a 2.3 Gingerbread update before my 14 day window is up. I'm happy for the DX1 owners who are about to be updated, but it's sort of insulting that there's still no word about it for the newer device.
Has anyone else tried Launcher Pro and gone back to blur because it slows the phone down so much? My DX2 was way more laggy than my DX until I went back to blur. And I mean everything seemed laggy. I actually still think they have a LOT of optimizing to do. My DX felt much more snappy running Launcher Pro than the DX2 is on blur. But I expect things to improve by patch 1 or 2 and as apps get Tegra aware. In fact I would be surprised if my slow laggy UI experience on DX2 isn't caused by something I installed.
And I'm still pissed that the setup wizard didn't launch when I pulled it out of the box. It really makes you feel like you got a used phone.
In order, fast to slow... DX w/LP, DX2 w/Blur, DX2 w/LPYour comment is a bit confusing to me. So which UI is snappier in DX2, Blur or LP?
From what I was reading, even with Tiered LTE, you get unlimited 3G, no?
DX2 w/LP is really a dog, but as I said, something else I installed may be a large contributing factor?
you are correct - I wonder if a higher class would help with the hd vid recording onto the sd card...
do you mean with redraws? i was getting a ton until i rooted and did the ro.HOME_APP_ADJ=1 trick.
Not redraws, the whole user experience feels slow and laggy. Lock Screen, screen switching, app launching, EVERYTHING takes longer than my DX pretty much.
Based on dev leaks, the current version of Gingerbread is causing excess power drain on dual cores and will be corrected in the next version. If this is correct, it would perhaps explain why no Ginger on the DX2, but singles cores are seeing the updates.
I posted about it in the Bionic forum and the info "fits" the rumors of battery drain troubles that scuttled the Bionic. Loose fit. I think I mentioned it somewhere in this forum too... can't remember.
Gingerbread WAS mentioned by VZW when the DX2 was launched, so it is not case of never seeing it.
I am having video recording issues big time. The only way I can get a decent video that does't hang or stutter while recording is to do a reboot then do the recording. Anyone else experiencing this?
so far i love my DX2! turn off all the crappy animations that slow everything down, slap on adw launcher, and this phone flies!
Can you elaborate on the turning off the crappy animations part?
