D
Deleted User
Guest
I posted this in another thread, then thought that I didn't want to pull that thread off-topic. So who is using SPB Mobile Shell?
It's sure freakin' expensive but you know what? I'd pay $15 for a launcher if it's awesome. The launcher is the part of the phone you touch the most, it's the basis for the whole user experience. If it's slick and efficient and usable, then bring it on.
Here's what I posted in the other thread:
Anyone else using it and like it? Sorry, but the ability to flip my phone into a 3D carousel isn't that useful, it's just pretty - and it ain't $15 worth of pretty.
binary visions said:I also don't think the 3d portion of Regina looks as nice as SPB shell, but then again I'm not spending $15 to try out SPB either.
I tried SPB.
It made me want to punch myself in the head.
It was all flash. No substance. No scrollable widgets. No options to set for preferences on how the shell acts. You can't place icons, they auto-arrange themselves. You can't even set the freakin' dock programs - it's either use the stock ones, or forget about it.
Incredible rip-off, IMO. Unless the stock design choices are exactly what you want, of course, in which case you might love it. But if it's not exactly what you want, pack it up and go home because you can't change anything.
I used it for about 10 minutes, then copied the APK and returned it. I copied the APK because there's no trial version and 15 minutes isn't long enough to evaluate a launcher - I would have re-purchased it if I liked it. So I played with it for another hour, felt like I was going to have to change everything about the way I wanted to use the phone in order to suit the launcher's rigid design choices, and deleted it.
