DX'rs Launcher-X now has scrollable widgets!
Steven58
Former Heavyweight Champion of Android Forums
Moderator
The problem with my DX using other launchers was that there wasn't enough room for the apps I wanted on there. I own LauncherX pro but it's gone dormant because you couldn't scroll it to get at the other apps. You had to press the button to move to the next several apps.
Well now they scroll. This makes other launchers, that don't have billions of screens like Go Launcher, more viable to me. I'm going to play with Launcher X on LPP tonight. :) :)
Update:
Using it on Liberty 1.0 with my own theme. Very unstable. Phone freezes up every 10 minutes. Not good. App frozen, now.
The launcher you're using has to have full support for scrollable Widgets in it. I'm running Darkslide 4.2 with adw ex and have zero problems with it.
UPDATE: There was a Launcher-X pro update. They fixed the FC's and the freezes. It works great!!!!!!
Newbies: Feel free to try it. You can trust it. Scrolling app icon selection is a great space saver. I tend to use a LOT! Having the choice of all those icons cuts down my need to have so many screens. I was using 13 screens with GoLauncher. Now, I'm back on LPP with its wonderful transitions! :)
I wish I could get LPP working without the freezes and bugs, I'll been sticking with Go Launcher until LPP gets the big update.
Air- did you get the latest update 2 weeks ago. Don't get me wrong. I like GoLauncher a lot, too.
