grdgc
there you goCan someone post the link? Sorry
https://www.dropbox.com/s/fux5ve9i28s6pif/cm12.1AB.zip?dl=0
Guys I'm ready to install everything but I have a question, how do I install a patch? Sorry for my ignorance in advance I'm relatively new to all this but learning fast
Thanks dude, I will do that. Here is a link to the cm12.1 patch, Angablade sent it to me yesterday.Well first we need a link for it then you install the patch just like you install the rom , so you would install the ROM then the patch then the gaps then reboot
The patch gave you a bootloop? Try using the original buildprop, the buildprop that the patch uses is based on the 4-16 cm12 build.Incakola said it should work on cm12 I think I might try it on on cm12 I tried to install the patch for hours last night I would not go and the APN thing is also no fun hopefully he fix It and thanks again for doing this for us. Will let you know if it works on cm12 in a few
At what part of flashing the patch does it fail? What's the output showing on the screen in twrp.Has anyone got the patch to work I keep getting failed I won't work for me has anyone got it to install? If so did it fix anything?
been really busy today at work, have not had time to test it.At what part of flashing the patch does it fail? What's the output showing on the screen in twrp.
"Welcome to the AB CM12.1 Patch..."
"Mounting system directory..."
"Copying files to your phone..."
"Setting permissions for files..."
"Unmounting system..."
"Complete! Remember!!!!!!!"
"Factory reset and clear cache..."
I keep getting failed as well
Do U have a "status" web page/site where U can post changes?At work. Will look into it once on break
?Pain in my butt
Can anyone say if the patch is working on either cm12 or cm12.1? Thanks.
The Best news are that you were not layoff... Thanks for been around GBY... Bro..Good news, I have the weekend coming up off from work.
