Noobified
I'll probably work on it next week. I have plans this weekend but I'm going to install cm now I can't do stock.How long will that take? i want to test it after you. (if thats ok)
I don't own one. They are very different devices with different CPU.please make a CyanogenMod 12 for lg f60 d392 or d390n![]()
Of course I could do it, but life is really taking a toll on me. I had to drop support on all devices I don't own it's a lot of work with debugging issues. Since there isn't even a booting build I would have to start from scratch which is something I don't plan on doing.then it is not possible?
Yes, this is the ROM. Thought it would be nice if the users of it could post and discuss here.
Of course I could do it, but life is really taking a toll on me. I had to drop support on all devices I don't own it's a lot of work with debugging issues. Since there isn't even a booting build I would have to start from scratch which is something I don't plan on doing.[/
The cm12.1 unofficial worked great if you don't mind not having a camera What made me revert back to ms39510d was the fact that wifi hotspot wouldn't work without going through isp data I am on metropcs unlimeted and i use wifi hotspot (fabio grasio) wifi tether router and it works flawlessly on stock ms39510d only recent update to 10e temporarily bricked device used lg flash tool to revert back to 10d However I am currently using a rooted lg leon If you want Id be happy to send you one (lg leon) to further your developmentOf course I could do it, but life is really taking a toll on me. I had to drop support on all devices I don't own it's a lot of work with debugging issues. Since there isn't even a booting build I would have to start from scratch which is something I don't plan on doing.
Let me know yes it is a low grade phone but it is definitely underrated currently only $29.99 it has potential
I am not giving up hope. I need my damn camera back bad for work. I'd go back to stock but no clue how. I've had no problems messing with any phone I've owned in the past.
Can I use this to remove http://androidforums.com/threads/e2nam-twrp-2-8-5-0-touch-recovery-lg-ms395.920337/? I am curious and would like to try allowing the update for this phone. But, from what I have read here, Recovery, will not allow the phone to update properly?You can use this as a guide to Flash F60 back to stock. You need the kdz file for the F60.
http://androidforums.com/threads/unbrick-guide-lg-leon-lte-metropcs-lgms345-kdz-firmware.923914/
MetroPcs LG Optimus F60 MS395 Phone Firmware MS39510G_00 KDZ
http://csmgdl.lgmobile.com/dn/downloader.dev?fileKey=FW75POA132JUAOI9F89DN8G/MS39510g_00.kdz
