DarkJohn55
Member
Just so everyone knows it's a arm32bit cortex 7 not 5
Typical.. I shall go to metro demand a newer phone and throw a tantrum, kick, scream, cry, and lob things around the store until 1 of 2 things happens. I get my way and they exchange my upgrade from 2 weeks ago, (highly pref) or... Cops come and they box me up, take me off the supported list and I end up with that old fat Nokia we all had at one point but its name will be Big John. We will become extremely close at some point. He wont be a good friend to me, its more of a "Hostage" relationship above all. But hey, at least I would be taking a 50/50 risk. Ill let you know how it turns out.
Really just posted that..
I just want an up to date(ish) phone for once.... Probably end up with Brain Cancer from this damn phone.. Possible I already developed some from the looks of this post... I really hope someone got a chuckle out of it. Then I can go on knowing I changed someones life.
♥Sin♥
Did you set it as default effects in settings/sound and did you installed V4A as a system app in priv-app folder? You may need to also switch SELinux from enforcing to permissive to avoid further complications (there's an app for that...).Anyone have viper4android working on this ROM? I'm on 7/23 and have the app installed, installed the driver, disabled nuplayer and can't seem to get it as default. Anyone have any success? And what steps they took
Hmm I'm actually not on cm right now so I can't play with it. I did have this similar problem with the Nexus 5. Had to do the same procedure but nuplayer wasn't ever the problem. Had to flash a certain ver of dspmanager libs for v4a to always work without switching compatible mode in settings (the libs were device specific). I did had success with v4a working on cm12(4-16 build). Maybe it's possible to use those libs or you could set fx compatible mode to compatible.Yep, I did the flashable zip, selinux is on permissive, audiofx was uninstalled yet still appears in quick toggles, I've tried everything and googling had been no help. I love viper and would love to have its audio sexiness back for my listening pleasure
I'm running 7/23 CM ROM also. I found this post in which I followed and it works. Enjoy! Also CM is already on permissive mode, so you don't have to follow the first step.Anyone have viper4android working on this ROM? I'm on 7/23 and have the app installed, installed the driver, disabled nuplayer and can't seem to get it as default. Anyone have any success? And what steps they took
This ROM is as stable as it will get. The camera is broken and as far as I know can't / won't be fixed unfortunately. Camera seems to be the only issue.Hey peeps! I just wanted to ask if any progress has been made, I know y'all put alot of work into this and I think we all appreciate that [emoji14] I'm super happy to see that there's actually people trying to sort this out, I would love to help if I can. I still have the stock ROM but am more than prepared to try this one out If anyone needs anything from the phone I'd love to help out!!
Thanks for all the hard work!!
You're probably right nobbish thoughts hahaGuys...do you not think that the ROM developer, Noobified, would have already fixed the camera issue if the solution was that easy before even coming out with the build?
Hey hello sorry new here.... but I would like to know if u can give ur latest build...most stable for the LG Tribute LS 660( gapps and cm 12 or 12.1)...I really liked what you did! if you can..much appreciate it (by the way anyone in need a stock rom for the lg tribute LS660 ...im more than welcome to give it to you!This ROM is as stable as it will get. The camera is broken and as far as I know can't / won't be fixed unfortunately. Camera seems to be the only issue.
Actually i have that phone too..not a big fan but..boost mobile version .and ..do u have the lastest build for 12 and 12.1? ...for tribute LS660 would much appreciate it if u had itMoved on to the lg g stylo guys. Better choice.
Yep ...I herd metro better...Boost gives 8 gigs of storage which is technically 3 gigs fo user and 1 gig ram...not soo good ....T mobile has a better stylo. From then boost mobile.Nah i dont have any builds for the phone and im on MetroPCS version fair Pryce upgrade for a decent phone
Nice! And lucky! Well ...I guess no Info on the Lg Tribute LS660 on any custom build rom...bummer...The one i have has 2gbs ram 16 gb rom so around 8 to play with
