jplsteel
@Noobified. Thank you. I'm using the 7/23 build. No probs. No lag. Video playback works. It's snappy and responsive. Other than the camera its a good build
@noobified,hey man you did one hell of a nice job on 12.1 this phone works better now than it did when I got it brand new.thank you so much for your hard work I'm sure I speak for a lot of others we appreciate your hard work thank you.@Noobified. Thank you. I'm using the 7/23 build. No probs. No lag. Video playback works. It's snappy and responsive. Other than the camera its a good build
Yes you will need to flash gapps to have google play store and other google apps.Do I need to flash gapps?
I'm running the latest build on CM12.1 everything is great so far but whenever I try to open apps such as YouTube that uses Google play services I get a message like thisand when I try to update the app it gives me this message
I've tried to clear the cache and force stop the app and even uninstall the updates but nothing seems to work. Any fix for this?![]()
Yeah I'm sure. I'm just gonna clean wipe and reflash again. The link that was posted for Gapps, which package do I download? x86, arm64, or arm.Did you make sure all the google apps were updated first such as play store app gmail google and google plus apps then try the google play store. If nothing works might have to reinstall with clean wipe such as advanced wipe data,system,cache,and dalvik then reinstall cm12.1 and gapps then wipe data and dalvik again and reboot.
yeah a full clean wipe should do the trick and here download this gapps file https://www.androidfilehost.com/?fid=23991606952613376 and flash that after the rom,Yeah I'm sure. I'm just gonna clean wipe and reflash again. The link that was posted for Gapps, which package do I download? x86, arm64, or arm.
Alright thanks. I'll do that right now.yeah a full clean wipe should do the trick and here download this gapps file http://downloadandroidfiles.org/fil....0.X/pa_gapps-stock-5.0.1-20150315-signed.zip and flash that after the rom,
Yea I just noticed that thanks.Sorry i replaced the file with the one from androidfilehost instead since the other link didnt load for me.
Alright. It seemed to have been fixed now. I'm not sure if the reflashing was the fix or using a different Gapps file was the fix. But thanks for your help anyways.Sorry i replaced the file with the one from androidfilehost instead since the other link didnt load for me.
I flashed arm64 works flawlesslyAlright. It seemed to have been fixed now. I'm not sure if the reflashing was the fix or using a different Gapps file was the fix. But thanks for your help anyways.
Are you trolling? arm64 is for devices that have a processor that supports a 64bit architecture. This device only has an arm processor...I flashed arm64 works flawlessly
LG F60 is 64bit CPU phone.eh? Qualcomm Snapdragon 410 (ARM Cortex A53 structure) is 64bit capable. Don't underestimate this phone manLG F60 is 64bit CPU phone.
I am also using ARM64 version of gapps, no issue at all. ARM(32) will also work since ARM 64 is backward compatible.
We are 32 bit msm8226/msm8926 snapdragon 400 not snapdragon 410 msm8916. You can check with adb shell or terminal emulator cat proc/cpuinfoWow so this rom is 64bit? Was stock also 64bit?
The US version of the F60 is the snapdragon 400 32bit. The international F60 is the 410
