Root EB01 (FROYO) Rom, Kernel, and Radio.
Guys this is not supposed to be posted outside of IRC yet. Its right in the topic. Anyone caught linking this outside irc is asking for a perma ban from that place.
Skater95 please delete this OP
Shouldn't this one be alright since adrynalyne posted to xda...I mean this is only a link to his post over there. Now...some other peoples' "releases"...another story.
Yes I see the link is to adrynalyne's and thats very fine I was wrong. I just in irc some people were really upset and I didnt know adryn has already linked it. So I was wrong and mistaken. Total my bad.
I hope skater95 reposts OP :o
Understandable, there's certainly some damage control in order atm.
Leave for a minute and whole world changes. A new froyo and voodoo or is that just red cmw for nonvoodoo I keep reading about? Should I flash this or is it not a big upgrade from dl30?
So far, my experience has been a tad buggy. However, this probably means I need to Odin back to square 1 to make sure everything is wiped, root, and go for it fresh.
I like it so far and it everything seems pretty fast. Only thing that hasn't been so great are the soft keys. I'm on voodoo and the lag is back. But this could also be exclusive to just my phone. We'll see after I go back to stock and then back to EB01.
So I want to make sure I have this straight. With the removal of the voodoo kernel (I knew I should have downloaded it this morning when I saw it), I have to install the stock EB01 to get the kernel, and then I can flash the superclean to run it?
superclean has a kernel packaged in...no need to flash the full leak first
woops, gotta do it again....I forgot to do the wipe first...oh well not a big deal...I am just used to wiping after I do the work...(yeah yeah I know..bad joke)
no no no, you cant just sweep this under a rug, we're going to need to sacrifice kittens now....sheesh...!
Done :p
Does anyone have a problem with the Battery staying stuck at a 100% for along time?
Nope, do you mean the accurate percentage stays at a long time before moving down to 99% or you have the stock image and it stays full for a long time before the 1st increment disappears.
I flash the aosp lock and battery it's stock at 100% image problem? Ok there is a problem on my lock screen it's showing 81% with asop battery icom is showing 100% still.
the voodoo kernel isn't working for me.. i'm not sure why.. any ideas? the robotic voice doesn't come on at all.. and i can't seem to enable it in CWR either
