Hello,
I need some help with my email settings. Now I did manage to set up everything so it works, but with an annoying glitch.
My university email uses different email name and username. Example, my email address is
myfirstname.mylastname@university.ca
and my username is formatted as : abcd1234
In my Thunderbird client, email and username are separate fields, so no issues with authentification. But in my android phone, there is only the email field. The only way I can get authentification to work is by using abcd1234@university.ca format. But here's the glitch : when I answer emails from my phone its uses the wrong address to send, which confuses the recipients.
Is there any way to have a username and email address that are different? Or any ideas for a workaround?
Android 4.0.3 on a Galaxy S2. Imap protocol.
Thank you
Thank you
