Root eMiui 2.8.3 (unofficial miuiandroid)
Status
Not open for further replies.
So how's the progress with this Rom been going lately? Would love to help!
I'm sort of waiting to see what happens, it seems phenom may be releasing jb shortly and if he does I'll stay on v5, plus the changes he has made to cm9 may actually make it impossible to continue MIUI. Right now I'm setting up my new os and looking into a different rom. I'll have something by this weekend if all goes right
We need update asap with cm9 working camera version n i dont think cm10 dropping yet anytime this year v5 will b super but been on same rom since day one it release at least release one version diz rom wit working camera thanks
JB is closer than you think. A few of us ran a pre alpha build that didn't have nearly all the fixes that he has in his current commits to his ics tree. (Including the camera and vastly improved power management.)
I tried updating today and it was a no go, just got a boot loop. Phenom off adding aokp like features in cm9 and it's causing the miui framework to not work with it.
Just tried flashing this ROM earlier today and for over 15 minutes, the boot image kept going. I ended up taking out the battery and restoring a back up because I felt that it was taking an awfully long time. Are such wait times common? I know that first boots after flashing can be long, but how long is it usually for this particular ROM?
Are you sure you went through all the steps before flashing?
Clear Data, Cache and Dalvik Cache then flash.
Yep. I also formatted, /system, /cache, and /data. After this, I went back to CWM and tried retaining data by restoring it from a Nandroid backup. I also went ahead and fixed permissions.
Never Mind. I kept forgetting to do factory reset, one of the biggest mistakes. I feel stupid. *facepalm* All good now guys.
The same theme or a different one? It's possible the theme didn't work because of resolution, would you mind uploading the log anyway? If you still have it
I think I didn't explain the original problem correctly; the app itself would load for a moment or two, then it would crash saying "Unfortunately, Themes has stopped." and it would repeat every time I'd try to open it. And, I don't have it anymore. Sorry D:
Ok so out want a theme that was crashing but the themes app
Status
