Oh no I was wondering if u knew how to do it but I just flashed the rom and I got the dreaded phone.apk force close so I couldnt do anything I flashed back to cm9 with my tar backup so its all good no force closes on it
# status bar shows roaming indicator off (i think its an easy fix just need to figure it out
I'm pretty sure you can fix this by placing eri.xml in /data. My github has the file for sprint and virgin mobile in the overlay folder.
I was able to get that problem fixed with the last release before i swapped back to CM9 for the improved kernel. I'm going to switch back in a few minutes, i'll PM you the fix once i refind it. it was just a setting buried somewhere.
haha yeah, I think it was a setting buried in with the carrier info. like i said, ill check as soon as i can flash over.
Hey do you know why music player doesn't work keep fc ??
No not really...does center klock work for u? And wat happen to compass n sound recorder apps n etc??? I see u add torch app and how kan get miui weather app? Every time try use weather widget says miui weather not installed
OK thanks just only issue left with is music player ...keeps saying unfortunately music player has stop. ..
Try download but link not downloading rom complete kan u fix or change link...p.s thanks for extra miui apps![]()
Kan u change miui apps to drop box 2??
So it include in new update? OK thanks for everything big bro![]()
