Root eMiui 2.8.3 (unofficial miuiandroid)
Status
Not open for further replies.
Full wipe as usual, (Data wipe, Cache wipe, Dalvik wipe) also fixed permissions after flashing!!!
Do me a favor if you are able. Can you so a full wipe, then go into mounts and storage, wipe system, and dalvik (under advanced) then flash Rom + gapps. Let me know if your still get a boot loop. It may have been a bad upload
I'll get to it in a few,....I went & tried the Gsnap update..lol (Serial flasher) :-D
Lol. Actually, try flashing WITHOUT gapps first.
If I upload a couple logcats can someone take a look? It looks like the keyboard issue is actually theme related
Still getting the boot loop,...Followed instructions to the letter!!!
Tried it both ways,..(With/without gapps)
i just checked devhost again and now it seems to be the correct size. Stay tuned. Also starkraving sent me a link to a version that may be better to use as a port. My daughter has a chior concert tonight so I can't promise anything but i'll do what i can, im also going to try a new port because as it is right now using the port may require too many dirty hacks to get working.
I just tried the link and the site is saying that the file size is 57.25 MB. When going to save the file, it also tells me that the file size is 57.2 MB.
I'm having issues with Mass storage also I tried going into storage and doing it manually but my computer still won't pick up my phone.
Hey. You know how you listed the data bars as being a glitch? They aren't. For one, you get faster speeds on the 3g, and also when you go through the testing menu (phone app, dial *#*#4636#*#*) and switch the mode from CDMA auto to CDMA only, the 3g bar goes to no signal.
Never intended to say it was a glitch, just that it's how it was. I know the double bars is standard but I still want to figure a way to only show one by default
Status
