garryknight
Just got my Galaxy S2 GT-I9100 on Saturday and set it all up. I'm now trying to understand the way the storage works. I know that my phone has 16GB of internal storage and can take a micro-SD of up to 32GB in size.
According to the Storage tab in Task Manager, it has 1.97GB of System storage, 11.5 GB of USB storage, and - in my case - 29.23 GB of SD card storage. I'm trying to understand how the phone's internal memory is used, and how this maps onto the file system, especially since the figures show:
System storage: 786MB/1.97GB
USB storage: 1.39GB/11.50GB
SD card 10.70GB/29.23GB
I assume that the 16GB of internal memory is split into two partitions: 1.97 GB of system storage and 11.5 GB of USB storage, with the missing 2.53 GB presumably as 'overhead', i.e. used by the system somehow and not available to me, presumably because of the way the partitions are set out. Is this correct?
Looking at the layout of the file system with ES File Explorer, I see the contents of my root directory, including all the usual suspects like /etc/, /lib, /proc, and /sbin, plus Android's /app-cache and /data. One of the subdirectories is /sdcard. If I look in there I find various subdirectories such as Android, Attachments, backups, Notifications, and Sounds, as well as data directories used by my apps.
Then I see two other subdirectories: external_sd and usbStorage. I realise that external_sd is my 32GB micro-SD card. And at the moment, my usbStorage directory contains nothing whatsoever.
So, if system storage is on one partition, and /sdcard is on another (so that it can be mounted, formatted, etc), then what is the usbStorage subdirectory? What is it used for?
When I unmount my 'SD card' in Settings/Storage, everything below /sdcard is unmounted. So am I to understand that everything above /sdcard is held in the 1.97GB of system storage? If so, then /sdcard must be where the 16GB (11.5 GB available to the user) of internal memory is mounted. And external_sd is mounted below this.
So:
1.97GB /
11.50GB /sdcard
29.23GB /sdcard/external_sd
0 /sdcard/usbStorage
So, my main questions are:
1) am I right about the way the phone's internal memory is laid out?
2) what is /sdcard/usbStorage, and what is it used for?
3) since my /usbStorage directory is empty, why does Task Manager show:
So:
1.97GB /
11.50GB /sdcard
