Has anybody figured out how to empty trash on the Nexus using gmail? I can't believe something so basic and often-used could be overlooked![]()
Do it from the web version of Gmail, instead of the app.
It's not basic or often-used for legions of us. Gmail automatically takes care of that, and there's no need to empty it unless there's a concern that another user will look through your trash.
I think people have a misunderstanding about GMail trash. GMail treats "trash" like a folder name. So, it's not like trash or the recycle bin on other OSes. It's basically a label and that's all it is.
Hmm in 2+ years of Android and 6+ years with gmail, I haven't once had the desire to empty my trash. Didn't even realize you couldn't do it on the mobile app. It looks like your only option is manually select msgs one by one and then mass delete. A select all option for the check boxes would be nice. I don't empty my trash (ever) but I could see me using a select all button for messages under particular labels that i want to delete (or tag).
They are still in that trash box. So, they are still taking up space. First I turned of sync, now I'm thinking if I delete the messages from gmail they will be gone from my phone?
So, does anyone know how to get those many messages off my phone to free up space. It's cool that Google gives us all this space but I don't want it on my phone, physically taking up space. If I keep the email on gmail and sync it with my phone is it going to try to put all the content on my phone?
How do I get it to start using the SD card for data storage and apps?
Thanks,
Bruce
What he said. I'd actually look at your apps to see what's running that may be hogging memoryThe Gmail app doesn't take up as much space as you think. On my phone, its using maybe 10 MB total, cache and all. On most modern Android phones, that's virtually nothing. And I have several thousand emails in my Inbox because I keep forgetting to delete them with 1 GB of my 10 GB used.
It isn't actually storing emails on the phone like POP and IMAP email systems do, they are just temporarily cached for a short time so you don't have to keep redownloading your latest email every time you open the app. They are constantly being downloaded and purged from the phone as you receive new email and after that, only loaded "on-demand" when you scroll past the first few messages.
So in other words, just let the Gmail app do its thing. Don't worry about how much space its using, since its definitely nowhere near many apps like the web browser.
