Root Enable SoftKeys (MOD)
aciulladev
Member
Hey everyone. I really wanted softkeys. So I got them by going into system/build.prop then go down to the bottom of the document and paste
Code:
qemu.hw.mainkeys=0
and reboot your phone. When it starts back up Baaam! You have soft keys enabled. Only problem is that it does not change the screen, it just overlaps the name of some apps.
Code:
qemu.hw.mainkeys=0
Nice find bro ;) check you pm box.
Edit: k it looks good but know when taking a screenshot the keys are in the middle of the picture, but actually there not.
I dont know if it was user error on my part, but my music player just died out after editing the build prop. After taking the addition off my props my music player worked perfectly.
Well since no one got back to me on this, i tried the mod again and my music player is still fcing.
Im getting a force close on the default music player. But go to the android market and download this app. And you can use it to download music or listen to music. That is what I just tested out and it worked perfectly fine.
Can someone explain what softkeys are to me. How does it benefit me?
Phones like the galaxy nexus don't have the home/back/menu/recent apps buttons on the phone, so it has on screen keys so you can navigate the phone. It allows the phone to be shorter and just a screen. People like the soft keys for cosmetic reasons so they enabled them. They could help improve battery life if you use them instead of having the light on the hard keys.
