So I've moved to California from Ireland. When I came over I picked up a cheap smart phone (Nokia Lumia 521) with MetroPCS as the service provider. After about 5 months of constant problems with the Lumia (Freezing, replacement phones, same problems) my friend said he would send me over his Galaxy S3 from Europe. So I get the S3 and it says I need an unlock code (Friend thought it was unlocked). So my friend calls the provider and gave a different IMEI code to his provider (Accidentally) and sent me on the unlock code. The unlock code gave me access to the phone but I can't connect to my service provider MetroPCS. It says "Unable to connect. Try later" when I try to do it manually.
So after getting I sent the correct IMEI code to my friend. He has sent me on a new unlock code. But now since I have access to the phone I don't have any where to assign the correct unlock phone?.
- Is it possible to fix this problem?.
- Is the problem to do with assigning the wrong unlock code?.
Thanks!
Thanks!
