How about some links.
Thanks
How about some "search" and "thinking" on your part. I told you where everything was, go find it
Thanks
How about some "search" and "thinking" on your part. I told you where everything was, go find it![]()
Not quite sure, I kind of wondered the same thing. I ended up going all the way --shutdown the phone, death grip to turn on (e.g. press all buttons --volume up/down, power, and camera), then selected "wipe cache partition" (use volume up/down to move cursor, press home button to select), then selected "wipe data/factory rest". That wiped all my settings (e.g. gmail settings, exchange settings, ..) and I had to reinstall my applications. Did not reverse my 2.2.1 update but, fixed my battery issues, felt like a brand new phone.
Confirmed^^^^^^^^
This worked for me. So far.....
Will update........![]()
I just plugged it in to charge @ 9:00 P.M. with 1/4 still left over and it's been almost 36 hours since the last charge........![]()
Okay so I am new to the whole rom thing and all but I have a few concerns. I just returned my epic for 1 reason alone. Battery life!!!! I got the iphone instead thinking the battery would be better but it is only slightly better. But can go 12 hrs under moderate use. Are these fixes good and true because I loved the epic and how user friendly it was. If I could get a solid day of heavy use without recharging I would go back but am hesitant and tired of paying restocking fees. Plus would it really work and how easy is it to do this rom thing?????
Tired of all smart phones being so dumb
PP
PS Phone and texting are my priority all else is geewhiz....plus I am a pilot and I can't just plug it in or recharge it in the middle of a flight unless I run a long extension cord
PP
Ok i am sure this is going to be a stupid questions, but i just got my Epic a few days ago, and was reading up on the forums.
What are all of you using that shows you what is using what % of your battery life?? Is this a feature of the phone or a app you are using?
Side note: I got a email from sprint a few days after I got my epic which had some walk-throughs on how to use/setup certain fetures with the epic, and one i noticed which might be good, but is not actually on my phone was: for me to hold down on the screen, then click on widgets, then click on program monitor, however there is nothing listed by that name. Any ideas???
Thanks '
does anyone have answers to my above questions? Thanks!
http://androidforums.com/epic-4g-ti...flash-rom-nandroid-update-ec05-more-come.html
Follow those great vids and you'll be wondering why you thought it was so difficult![]()
