Joscelynsmommy
+1Non GV user have to type password in when I restart...
Alright guys heres some info and things i found
I tested out service in my store. Side by side with another eris.1.5 full bars. Mine 2-3. Debug mode. Both had same dbm . In VZW stores there is a receptor to give full bars voice only not 3g. I came to conclusion that possibly we are seeing our 3g coverage and when we call we see our bars jump since it switches to just voice. I still think its a bug tho because in battery use i get between 40-90 percent no cell service which is wrong.
Also I called HTC. They said we will be able to update more than likely ota because this isnt the final build and that people within HTC are using what we are and it is the tester build. He said he has heard of a lot of bugs. He also said we would have no problem installing the Rom from pcdphones.com whenever update is out.
Also in quick settings it says no vpn. He told me that that is what is causing us not being able to click certain links and apps and was shocked when i told him there was no vpn.
Hope this clears few things. He didn't say when a update would come out even knowing I work as a tech for vzw. he also asked if i got the live wallpapers to work.
Sweet some backup to what I was thinking sitting under our repeater at work. At home against the wife's 1.5 eris signal meters are about the same, hers showing 1 bar more occasionally but with the distance to the tower it would make sense I'm getting a DO reading vs her 1x readingAlright guys heres some info and things i found
What about the camera not being able to shoot in portrait mode now? Or am I missing something...
I don't know if this has been answered already but when I'm in a phone call, the person on the other end of the phone says they are hearing an echo and the speakerphone is NOT on. Is anyone else experiencing this problem after the update?
Anybody else's phone vibrate before you make a call? Any fixes?
Sent from my Eris using Tapatalk
One other question: I used Astro to back up my apps and loaded them onto my phone from the SD card after I updated to 2.1, then I checked the Market and realized it didn't recognize any of those apps as "downloaded." At that point, I figured that automatic updates wouldn't be recognized for any of the apps I just loaded locally so I just re-downloaded them from the Market. Has anyone else come across this or can let me know if the Market can tell if you need an app update if it's not in your "Downloaded" list?
Ok, so I guess my question might have been too long or poorly worded. This is mostly directed at anyone who is not experiencing a "Time without a signal" around or above 50%. If you aren't experiencing this, do you have any idea why? Does anyone else have any idea why?
Oh noes!!!!11!!eleven!! Why are you trying to install a leak on a phone that isn't yours? Ota will be a
round soon enough
