So *228 fails. It gets to the Programming Phone part, and never gets to SPL Unlock.
Is that what you used qpst tools for? Changing the SPL Unlock code to 000000 ?
Did you update your PRL file? You have to have the Correct PRL file for *228 to work. And it has to be for the market you are in. I can help you look for it if you want.
The unlock code should be 000000 by default. I didn't use any tools to program it.
38199.prl looks like what I need. According to the old phone.
Try it!.....going to work out for an hour but will have my phone with me and will check for updates, sounds like your getting close.
I just thought of this. You are putting the file on the sd card then selecting update PRL in the programming correct?
Should I put in the MDN (phone number) before *228?
I'm also going to Home SID/Home NID, and putting in 5361 for the Home SID (Since the Cricket guy gave me that as the 'SID'. Should I leave this at 2004 (as Verizon has it) before I *228?
HAHAHA I just saw your user ID on Cricket Phone Talk, ROFL. Small internet.
Cricket Phone Talk StatisticsThreads: 1,128, Posts: 5,361, Members: 4,940![]()
Welcome to our newest member, pkopalek
LOL I told you I was looking!
*228 just gets nowhere. I'm making sure the old phone is turned off. The programming music goes on for about 2 seconds, then is gone. It doesn't even say SPL Unlocked! or get into any of that. Trying with ALL PST settings put in.
Last time I did that, I went to *228 a second time, and somehow, with ALL cricket settings in, it called VERIZON activation! Go figure!
Yeah none of the local crickets do it. They send phones that need to be flashed, away.
Perhaps the Cricket customer service guy will e-mail it to me?
I'd extract it from the phone if her old phone would just show up in Device Manager as one that I can set to COMX, but it's just showing up as a flash memory storage device. Lame.
I try to make calls without *228 on a generic one and get nothing useful. It's a pain. I'm gonna try cust service tomorrow to see if they can help.
I'm a bit taken by *228 not working. Perhaps I should call Cricket and give them the MEID that's going on that number, and then try again?
All I did was ask for my #'s and tell them I was going to *228, and they wished me luck.
*228 just literally does nothing, which I find strange. usually it will tell me a reason activation failed. It just tells me to go to a store to get it activated if I have Nationwide Roaming (which she does).
There are others in Buffalo who have used PRL 1042 to *228 without a problem.
Did you tell them your MEID first? Should I do this, and then maybe I would find success in activating?
Why do you need *228 to work? It doesnt work on my phone and everything works, -mms
