I've been having a problem with my device dropping the wifi connection every time the screen goes off. 6 times out of 10 or so it'll reconnect quickly when I use the device again but sometimes it does not and I have to cycle the wifi to reconnect to the routers (it'll say the wifi connection is out of range and can't connect).
I want it to stay on wifi at all times when inside a wifi area and I have wifi turned on to minimize the verizon data being used. You can set this like so:
Click: settings > wireless controls > wifi settings
Then Click: menu > click advanced >
Then Click: wifi sleep policy > click never
I'm testing it out now to see if it has any bad affect on the battery life. From what I understand the wifi chip takes less power then the 3g chip so it should in theory use less when wifi is available.
A long press of the send key will bring up voice command. Just speak "open battery info" and you will get a lot of interesting info, same as hitting *#*#4636#*#*, but easier!
added to top, if we can find a list or discover more voice commands i will add them as a group. thanks sg
How do you set the wifi to never sleep?I can't confirm if that is true or not. I've read that a few times in different forums.
I have been running it with the wifi set to never sleep now for a day and a half and my awake time is less than 8%. When I had it setup as default my awake time was 30%. I'm in wifi areas a lot more often so now it's pretty much always connected to wifi and it's using a lot less battery now. at least from a little more than a day of use like this
Thanks, do you have mobile network enabled during the time you are using wifi or is that turned off permanently with wifi permanently on?click: settings > wireless controls > wifi settings
I've now been running this since I first posted that I was trying it. Working out great for me. Phone just recently took 2 days before needing to go on charge (even had the GPS turned on the whole time too) and the amount of 3G data usage is down by a ton.
One of the better apps I found is one called "Quick Settings". With this app you can quickly turn on or off Ringer, Bluetooth, Wi-Fi, Network Data and GPS Receiver.
the Network data toggle? Is that different from turning mobile network on and off?
Is that true that the wifi uses less power than the cell radio? Can someone confirm this?
I am a new user of the Eris and I know that we have the 3G for internet usage so what would be the benefit of using the Wi-fi when we have connection through the 3G network?
Has anyone heard when the Andriod 1.5 will be upgraded to the 2.0??? I am dying to have my voice-navigation back. I recently switched to this phone and this was one of the features the "sales" guy told me I would have. Well lesson learned after the purchase, that I can't use voice-navigation because of 1.5 version.
