Root eris to droid
Yes! Rooting will create a physical keyboard, increase your screen size by half an inch, and increase the resolution of your screen. /s
What exactly are you asking?
Yes. After rooting, do a search on these forums for an app calles Transformerphone.
Once you have a rooted transfrmer phone, you can change it into a Droid, iPhone.. or a toaster if you preffer
can i get my eris to run as a droid through rooting
lol! these guys are just messin' with you (we do have a little fun here on AF, after all) :p
Sounds like you really want to have a Motorola Droid "look and feel"...I'm pretty sure that there might be skins, themes, or backgrounds or such to do so, but most of what I've seen was to make things (launcher, etc.) look like the Nexus One. Some of which might require root, some might not.
You'll just have to do some searches in these forums and possible over at xda-developers.com. Also, try a Google search with "androidforums.com" at the beginning of the search string with stuff like "droid theme", etc.
Good luck.
Good luck.
lol... you're way too nice for a scray looking alien....
Bnelson0392... welcome to the forums.
Just having a little fun, as Scary Alien said, since your post wasn't very clear.
We are all happy to help, but you really need to be more detailed as to what you are looking for.
If what you meant is to run as fast/smooth as a Moto Droid, the eris isn't quite that fast.
Howevre rooting will help improve the eris' speed by allowing you to OC and a few other things you will discover once you are rooted.
Good luck
Reading over in the Droid forums, I've noticed that many there have been able to get their Droids to run like Erises.
Most start by ignoring the silly Mattel-like slide-out keyboard.
lol, Most over there are not fans of anything like sense ore moroblur but the keyboard is spot on. I only use the keyboard when using terminal emulator.
