ES File Explorer on Jellybean question
jgreetham
Hi all,
I've just updated my T-Mobile Galaxy S2. I notice in ES File Explorer, my preferred file app, that the "external_sd" folder is empty. The stock My Files uses extSdCard folder to go the the external SD card. But I don't see that folder in the ES File Explorer.
So, how do I get to the external SD card in ES File Explorer?
Thanks all! I tapped the Favorites icon and the /storage/extSdCard was already there so I just tapped it. Now when I tap "back" it will go up to "/" where previously it would exit.
With a long press on the 'Up' button you can exit ES at every directory place :)
Harry
