Root eSnap 1.8 LG-UI 3.1 for elite - September 19 2013
Status
Not open for further replies.
I uploaded a new version (1.6a) that fixes a few things I recently found. It is recommended you update to the newest version. I wasn't able to include all the fixes yet because a few files I need don't seem to want to download. Hopefully tomorrow.
Do I just flash this right over the current Install? And do I need to reflash gapps?
Interesting since it requires 2.3 or later and I'm running this rom.
Not a rom but it would be helpful is getting native tethering working or a 3rd party app so nexus 7 and my ps3 will tether to my phone. All 3rd party apps I've tried transmits on bands that neither can read but my PC will .
Edit..sort of posted in the wrong thread but guess it also fits here . Was meant to post in the thread where you asked for suggestions lol
Not sure what you are implying but I assure you that I used phenoms cm9, the build from 9-30-13 which is android 4.0.4 to build this one.
Teathering via wifi tether for root users works just fine for me.
No doubt the rom is above requirements for the site but the site apparently doesn't know that. Also on tethering neither ps3 or nexus 7 see my phone when tethering
had one issue with superuser on the 1.6a update. when trying to update the binaries, it crashed to boot, like a hot boot, just reloaded the rom. I just took for granted that the update went through. it's been giving me some trouble on an app called greenify that I use to manage what apps stay in the ram. but after updating the binary successfully, greenify works fine now. I have logcats during the superuser request loops that greenify was giving me, but as it's working now, I'll spare you them unless you want it.
This is the next thing i'm trying to fix. I think what is happening is that the system tweaks are messing up the su binary permissions. When this happens go into app settings, clear data from superuser and update the app. It should work.
I also, just did a few back to back qr code scans with a couple apps. I get a camera error with a bunch of numbers. Should I let phenom know too since this is based on his ICS? Only does it for qr code downloads so far. Other scans, like when I scanned a candy bar, worked fine.
yes, let phenom know because I haven't messed that deeply in the cm9 base which means if there is an issue it's a general cm9 thing and not just a gSnap thing
Can the PS3 or Nexus 7 see adhoc? I know I've been trying in vain to get an AP connection from the elite
I'm finding lots of posts of people with the same type of issues, unfortunately the only solution i've been able to find is, turn airplane mode on the nexus on then off and try again.
Great Rom. Everytime I start the Rom it says "Unfortunately, Home has stopped" and then my wallpaper gets bigger. Do you know why? Thank you
E/DatabaseUtils( 4177): at dalvik.system.NativeStart.run(Native Method)
E/lights ( 244): write_int : /sys/class/leds/button-backlight/brightness 255
E/[LGHome]NumberBadge.LGUnreadGmsEmailsBadge( 3070): [LGUnreadGmsEmailsBadge.java:90:countUnreadItems()]Cannot reolve unread items
E/[LGHome]NumberBadge( 3070): [LGNumberBadge.java:114:handleMessage()]MSG_RESPOND_RESULT_FROM_PROVIDER_FAILED
I/dun_service( 158): The value returned from dun_getusbmodemstate_fromsys is 1
I/dun_service( 158): Post event 1
I/dun_service( 158): received event: DUN_EVENT_USB_UNPLUG
I/dun_service( 158): received event(DUN_EVENT_USB_UNPLUG) in state(DUN_STATE_USB_UNPLUG)
I/dun_service( 158): Ignoring the event DUN_EVENT_USB_UNPLUG in USB_UNPLUG_STATE
I/dun_service( 158): Moved to state(DUN_STATE_USB_UNPLUG)
E/DatabaseUtils( 4177): Writing exception to parcel
E/DatabaseUtils( 4177): java.lang.IllegalArgumentException: Unknown uri: content://com.android.email.provider/unreadmessage
E/DatabaseUtils( 4177): at com.android.email.provider.EmailProvider.findMatch(EmailProvider.java:440)
E/DatabaseUtils( 4177): at com.android.email.provider.EmailProvider.query(EmailProvider.java:1743)
E/DatabaseUtils( 4177): at android.content.ContentProvider$Transport.query(ContentProvider.java:178)
E/DatabaseUtils( 4177): at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:112)
E/DatabaseUtils( 4177): at android.os.Binder.execTransact(Binder.java:338)
D/wpa_supplicant( 460): wpa_driver_wext_driver_cmd RSSI len = 248
D/wpa_supplicant( 460): wpa_driver_wext_driver_cmd YSXC9 rssi -58
D/wpa_supplicant( 460): len = 15, 15
D/wpa_supplicant( 460): wpa_driver_wext_driver_cmd LINKSPEED len = 248
D/wpa_supplicant( 460): wpa_driver_wext_driver_cmd LinkSpeed 19
D/wpa_supplicant( 460): len = 13, 13
D/dalvikvm( 4177): GC_CONCURRENT freed 1443K, 29% free 6080K/8455K, paused 2ms+5ms
D/dalvikvm( 244): GC_EXPLICIT freed 372K, 40% free 6404K/10503K, paused 3ms+5ms
D/dalvikvm( 4177): GC_FOR_ALLOC freed 1121K, 32% free 6075K/8839K, paused 34ms
D/dalvikvm( 4177): GC_FOR_ALLOC freed 120K, 30% free 6203K/8839K, paused 24ms
I/dalvikvm-heap( 4177): Grow heap (frag case) to 14.612MB for 516044-byte allocation
I/dalvikvm( 4177): Jit: resizing JitTable from 4096 to 8192
D/wpa_supplicant( 460): wpa_driver_wext_driver_cmd LinkSpeed 39
D/dalvikvm( 4177): GC_CONCURRENT freed 1991K, 43% free 5964K/10375K, paused 3ms+3ms
I/ActivityManager( 244): Start proc android.process.acore for content provider com.android.providers.contacts/.ContactsProvider2: pid=4436 uid=10001 gids={3003, 1015}
I/ActivityThread( 4436): Pub com.android.voicemail: com.android.providers.contacts.VoicemailContentProvider
I/ActivityThread( 4436): Pub user_dictionary: com.android.providers.userdictionary.UserDictionaryProvider
I/ActivityThread( 4436): Pub com.android.social: com.android.providers.contacts.SocialProvider
I/ActivityThread( 4436): Pub applications: com.android.providers.applications.ApplicationsProvider
I/ActivityThread( 4436): Pub contacts;com.android.contacts: com.android.providers.contacts.ContactsProvider2
I/ActivityThread( 4436): Pub call_log: com.android.providers.contacts.CallLogProvider
D/chromium( 4177): Unknown chromium error: -400
I/ActivityManager( 244): No longer want com.android.providers.calendar (pid 4297): hidden #4
D/wpa_supplicant( 460): wpa_driver_wext_driver_cmd YSXC9 rssi -57
D/wpa_supplicant( 460): wpa_driver_wext_driver_cmd LinkSpeed 52
W/AssetRedirectionManager( 244): Unable to attach target package assets for com.android.gallery3d
D/dalvikvm( 244): GC_EXPLICIT freed 234K, 39% free 6408K/10503K, paused 2ms+11ms
D/dalvikvm( 4177): GC_EXPLICIT freed 819K, 40% free 6259K/10375K, paused 2ms+9ms
W/AssetRedirectionManager( 244): Unable to attach target package assets for com.groupon.dev
D/webviewglue( 4177): nativeDestroy view: 0x655b00
The home issue is on my list. Hopefully I'll get to it soon, thanks for the logcat, it looks like its missing some resources and resets when it can't find them. Right now I'm trying to get paranoid to a workable state then I'll look into this
It seems that the launcher is missing some lg specific smalis. I'll look into it soon, right now feeling kind of meh
Status
