Help Esteem not reading sd cards
Hendoe
so i when to put a 8 g card ( one that i reformatted) and tryed to pop it in and it was picking up the old 2 g card. so i took the card out and left it with no card and still its reading a card that is not in the device... can any one help me.....
Go into "SD card & phone storage" in your settings and click "Unmount External SD card":dontknow:
i did so and when i re mounted it it read the card but when when i go in to applications,manage apps when i touch on sd card the old one is still picking up and not the new one:hmmmm:
That's because it is reading what is on your internal SD card (4GB internal )
To see what is on your external you can use an app like Astro or Root Explorer:)
i have both... will i be able to trash all the bs i donmt want? like old apps?
off topic.... i had zvc and upgradesd to zvd, is there any way i could take off the zvc to free up space ?
i see.. thank you sir. when i connect my friends esteem in to a computer the internal mem is full. and insted of it being a blueish color its in red. i went in and truyed to remove some of the bs and it made no differance... what would cause this?
For sure just uninstall them.
Those are versions of the phone software. Once you update the previous version IS gone.;)
Too many apps n downloads n data n backups in internal.
You need to go into the settings of each culprit (btw there are other apps that backup, not just the traditional backup apps) and change to external their download n data...those that well allow, that is.
You may have to delete and or Manually Move to external all downloads n backups.
The directory structure to access external is: /sdcard/ExternalSD/Downloads(for example)
Edit...n to access internal is say, /sdcard/downloads....some apps create their own...like /app name/download...
And U'll have to make executive decision which apps to move to external...perhaps sort them by largest size n move the least used ones. Some should not be moved...system, widget, browser, multimedia, those that need to run constantly....
Good luck...
Sent from my LG-MS910 using Tapatalk 2 Beta-6
