Root Evo 2.3.3 rom,kernal,tethering
mankinda
Hi guys
i have tried reading all these threads and am still puzzled. I rooted my phone and have s off now from following revolution guideline
can anyone help me get started and tell me what rom to get how to get it and i guess one that is supposed to help me get wifi on this phone so i can use my home computers .this is all new to me and i just dont get it with roms ,kernals,nandroid backups,etc..i simply want to use my phones wifi you guys have sent me links ,etc but i just dont get any of it..what i do know is when i reach hboot it does say s off
thanks
So.. once you get to the Hboot white screen. Do you see something that says Recovery? If so, go to it. Once you click the power button to select Recovery, your phone will display a white screen acting like its going to fully boot up, but it will take you into recovery mode.
Once in recovery mode, to make a nandroid backup, go to Backup & Restore, and from there it will ask you if you would like to back up or restore. Select Back up to make a nandroid of your phone. Make sure to keep the first 3 items checked, and also select your wimax keys to backup.
Then go back, and select Reboot System.. Your phone will reboot..
As far as tethering goes, there is an App on the market called "Wireless Tether" download that, and tap the screen, and you should be able to broadcast wifi
so.. Once you get to the hboot white screen. Do you see something that says recovery? If so, go to it. Once you click the power button to select recovery, your phone will display a white screen acting like its going to fully boot up, but it will take you into recovery mode.
Once in recovery mode, to make a nandroid backup, go to backup & restore, and from there it will ask you if you would like to back up or restore. Select back up to make a nandroid of your phone. Make sure to keep the first 3 items checked, and also select your wimax keys to backup.
Then go back, and select reboot system.. Your phone will reboot..
As far as tethering goes, there is an app on the market called "wireless tether" download that, and tap the screen, and you should be able to broadcast wifi
i did that backup when i followed the rules on revolution so that was done.i just need to get tethered and was told i would need to flash a rom and have no idea which one or where and how to get it
Well to tether your phone, you can use Wifi on your stock rom that you ROOTED.. I would use Wifi with my stock rom after I rooted my phone. I have done it plenty of times for about 7 months before flashing my rom recently to MikG2.5...
Here is the link in the Market for the wireless tether..
https://market.android.com/details?id=android.tether&feature=search_result
Just download on your phone through the market, and run it.. it might ask for super user rights, just allow it, and tap the screen to start the wireless tether
Here's a review for the app, Now I know the user isn't using an HTC Evo, but he or she is rooted..
Works great on HTC Thunderbolt
April 19, 2011
Wireless tether works great on stock ROM, stock kernel. This app creates true infrastructure style hotspots and not just ad hoc hotspots. Works great with Macs, Kindles and other devices like the Cr-48. Similar to MyWi on jailbroken iOS devices but much simpler and more powerful. Allows users to authorize devices using the hotspot; keep those freeloaders off your network even if they somehow break your password. Best part? It's FREE!!!!
You can flash one of the mikg roms or synergy based roms and they have the wifi tetherer and hacked sprint hotspot built into the rom
so could you tell me where to get the rom and how to flash it? I would really appreciate it
look at the stickies of this forum. there is a http://androidforums.com/evo-4g-all-things-root/284413-roms-kernels-download-page.html sticky. also you can head on over to EVO 4G Android Development - xda-developers as well to checkout the new roms.
in the http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html there is a section on flashing. follow the instructions there. also if you have not already done it, i would recommend that you switch recoveries to amon ra 2.3. in the guide there is also a section on recoveries and how to switch recoveries. but that is up to you.
